coilover with spacer?
hoss55
looking to buy set of coilovers for my 2wd. has stock suspension up front with 2 in spacers. can i use the spacers with the new coilovers?
which coilovers are you looking at? And what type of spacer are you running now? A Top plate spacer or one that goes on the spring? We need this information before we can help you.
I don't think that kit will work in conjunction with a coilover, at least I would not recommend it. Most coilovers are adjustable for height, so you should be able to get lift without a spacer.
ok thanks alot. so basically i should just remove the whole front strut and spacer completely and put in the coilover and ill have the right height?
erinobr2000
