4runner Fox Pro front Coilovers
Az4runnin
Senior Member
I've been searching, but I cannot find a definitive answer. I'm looking to see how much front lift would 4runner Pro Coilovers and Eibach Lift Springs give my 4th gen V8
Are the pro's like the 2 or 2.5? With my 2.5's, they came pre assembled BUT I could adjust the height. If they are adjustable you could probably change the lift height.
HOWEVER, if they are like Bilstein's, you may need to have the perch set at the lowest level in order to use those springs.
I am specifically asking about the Fox TRD PRO set up from a 4runner or even from a Tacoma too.
Did some digging brother, looks like the front will net 1.4"-1.7" of lift over OEM, and rear will net 1"-1.25" lift with the specs given.
I am looking at 3rd Gen Fox Tacoma Pro fronts. If Tacoma Billy struts give 1" right out the gate on 4th gen Runner wouldn't the Tacoma Pro's give me about 2 1/2" up front then? I thought I may need the Eibach Pro front lift springs but that may be too much according to all the #'s. There is a 5/8" difference between stock Pro and Eibach Pro front springs. Mine is V8
Bunkstaff
