Color keyed door handles and rear garnish?
deedst4r
I am sure someone knows where i can find these. I searched for hours and found nothing. Any help is appreciated!
The easiest way to find these part numbers is to go to your dealership and tell them what you want and get the part numbers.
Once you have the part numbers, go to one of the online Toyota dealerships, such as Conicelli Toyota, CamelBack Toyota or others, and order the parts.
Or go to Conicelli directly, give them your VIN and tell them what you want, and they will give the part numbers, etc. Either use the net or phone.
Conicelli is just one dealership located in PA that's closest to you with reasonable prices.
Conicelli Parts Center
CamelBack Toyota in AZ is one I have been using cause it's close to me.
Camelback Toyota Parts
I have done business with both and they are ok, but there are other online dealerships that people use on this forum.
I did a quick looksee for the liftgate garnish/handle for your 07 SR (Dark Blue?) and the handle is $151, but it does not give me the part numbers. I did not look for the door handles.
Thanks! These all look really expensive though. Does anyone know any other places/ways to buy these parts? Also has anyone had these painted at a shop or done it themselves?
usually toyotapartszone and conicelli are the cheapest or as cheap as anyone else.
momo painted his door handles. You can find most colors of toyota paint at auto zone, advanced, etc. in Duplicolor OEM Match spray cans, to look well you'll also need the Duplicolor OEM clear coat.
i highly suggest buying the factory painted ones. I had my door handles done on my Tundra and after a awhile they ended up getting chipped. I think I paid $100 for the paint work and you can get them from Toyota for like $150 for the set.
Check out TRDsparks.com if you use the parts search diagrams you can find the part #s
No luck with the junk yards.. I think I will be attempting to paint and then we will buy these parts if needed. I am going to try and get help from Trevloc and momo about painting. I just don't think it was worth $312 at this point. Thanks y'all!
