Coming Soon - Direct Plug & Play Rigid Industries Fog Light Kit 2014+ 4Runner
PN - 46540-KIT-PNP
We know a lot of you want to upgrade the fog lights on your 4Runner to LEDs, but dont like the idea of hacking into the factory fog light harness or having to route a wiring harness thru the firewall. Total Automotive Performance has the solution! A 100% bolt on / plug in system that is easily reversible featuring the newly released, street legal Rigid DOT/SAE Dually set. We also include a set of the Rigid Dually brackets for the 2014+ 4Runner as well as a plug & go MRT harness which adapts the Rigid lights to your factory fog harness.
This system has been proven with our Tundra & Tacoma systems and will soon be available for your 2014+ Toyota 4Runner.
EDIT: These are now in stock and shipping!!
Product Description:
2014+ Toyota 4Runner Dually Fog Kit – This Rigid Industries fog light replacement kit is designed specifically for the 2014+ Toyota 4Runner and allows for a clean, OE-quality install of Rigid Industries high output lighting. This kit allows you to install our D-Series LED lights (included) in each fog light opening in the lower front bumper of your 4runner. This kit includes a wiring harness that makes it a simple plug & play install. Made from laser-cut 304 stainless steel, it features a high quality black powder-coat finish. Installation is simple, using basic hand tools, and requires no drilling or cutting. This kit includes all necessary hardware, and features Rigid Industries’ limited lifetime warranty. It is 100% bolt-on & reversible.
Includes:
Rigid 46XXX – 14+ 4Runner Fog Brackets
Rigid 50481 – DOT Dually Pair
MRT H11DT – H11 Conversion Harness
DOT Dually Output Shot
Check out our complete line of Plug & Play Rigid Industries Fog Light Kits for Toyota
Talk about putting a square peg in a round hole....
Looks good though. Would be most effective with [MENTION=65614]Antman[/MENTION] 's Independant fog light switch mod.
That is a great idea! Having the option to have them on their own circuit is a must!
I'll start mortgaging my house or selling meth in advance to afford this.
You may only have to sell a little meth if you get in on Jickos GB
http://www.toyota-4runner.org/sale-...e-introduction-*group-buy*-spring-2015-a.html
[MENTION=120150]TotalAutomotiveLV[/MENTION]
Believe the answer is "no" but any chance this kit would fit the older 5th gens (2010-13) fog light housings or aftermarket bumpers that reuse the stock fog lights like Shrockworks?
Yup, I am wondering myself. Was about to get the Tacoma SR mount but would rather run dully's in there.
OR.....these are also a direct swap, round_ so they fit exactly like OEM and you can buy them right now for $70
http://www.theretrofitsource.com/closeouts/b-stock-morimoto-xb-led-fogs.html#.VUsTZxFFCUk
Already have those and personally I think they are garbage. The stock fogs have a much wider spread of light, which is desired in a fog. But since the truck is high off the ground, no need for a true fog.
Going to go with an Amber Dually to complement the SR 30 in Amber on the front bumper. White light will be handled by the Vision X Cannons on the ditch brackets and a to be named 40" LED bar on the roof.
A goo company to purchase film from would be Lamin-X also, I would disagree about your assessment of the fogs, but I do like the idea of the Vision X on the ditch brackets
Think I am just going to do straight amber LEDs.
Are you double stacked on the ditch bracket? Or is it just the camera?
I'm down for a set in Amber....just have to wait until it is confirmed they are available and on hand from the manufacturer. If the recent Gobi group buy taught me anything, I can't stand to wait indeterminable amounts of time between payment and product arrival.
We can do it with Amber dually or d2 lights if youd like. Everything is in stock as of now except for the brackets. :)
Brackets on the Limited same as on the SR5/Trail? I'd be interested in these for sure, I like the integration and have been wanting to add lights without making the front end too blingy looking. I'd also like to see a close up shot of the lights.
Here is the DOT/SAE dually light we are including with the standard kit.
peacefulpiranha
