Common mods/upgrades for standard offroading?
Zim
I just bought a 1996 4Runner, 189K miles. It's in pretty good shape.
The first thing I want to fix is the sagging rear end; I read the sticky for the various approaches. I'm not interested in lifting more than 1" so I'll probably go with the Highlander or OME springs; not sure about shocks?
Anyway, I'd like to know what common upgrades/replacements I ought to make first. I plan on taking this vehicle on some occasional lengthy highway trips, plus frequent weekend excursions in fairly rugged terrain (southern AZ), but no rock-crawling or super-technical stuff.
Thanks.
tires. front & rear recovery points. should already have a front hook and you can get a reciever shackel if you have a hitch. if not you can bolt up a hook.
Thanks.
If it's an automatic, put in a new radiator.
And these are so I can be towed/winched out if I get stuck? Are these pretty simple to attach oneself or do they require welding or what? Thanks.
Bigger tires and sliders are two of the best first things you can do but even in stock trim a 4Runner goes pretty far.
Proper recovery gear including hi-lift jack.
265/75/R16 sized tires. Will fit w/o lift. Get ones with good sidewall.
Rock Sliders.
There is a lot you can do, but the 3rd gens really are pretty capable out of the box.
You can also find some info about off roading alone here.
