Complete Rear Link kit now available!
ToyTec Lifts
We have just released our complete rear link for the 3rd gen! This kit includes our DOM lower links and the panhard bar as well as the newly released upper links too!
^^Click me^^
Made from 1.5" X 1/4" wall DOM tubing, with fully adjustable PTFE lined, 28,090 radial load heat treated rod ends.
These rear control arms and panhard bar are as tough as you can get!
Offers the ability to fully adjust your rear pinion angle and adds rear flex to your lifted 4runner.
This New 3rd Gen 4runner link kit includes:
- (2) Adjustable upper rear control arms
- (2) Adjustable lower rear control arms
- (1) Fully adjustable Panhard Bar
- (1) Panhard drop bracket *must be bolted and welded in place*
PM me with any questions!
Nice kit. If I wheel more, I could see that being very useful.
Question though, why does it come with the panhard bracket AND the adjustable panhard bar..
Finally someone is making a full set. Design looks good. 1.5" .250 dom is pretty hard to bend on a short link like these.
Only thing is the 3/4" heims on the lowers... I would say 7/8" is the minimum on any link that will see rocks.
Total Chaos Rear links
although those do have the 7/8" heims :shrug:
Wow, the gusseting on those are insane... Are those for 3rd gens or for newer applications I wonder?? Hella expensive, but if you're gonna stick with your 8" rear and do heavy crawling might as well. Maybe down the line when I stop giving a crap about the body :D
They are for 3rd gens sorry linked the wrong product the first time Total Chaos Extreme links 3rd gen
I think I can find better things to do with the extra ~$400 though
The drop bracket will get the bar closer to level which will increase the effectiveness of the panhard bar. Also, the bracket will correct the arc of the axle so your driveshaft doesn't get sent into the gas tank as much rather than just using the adjustment of the panhard bar. After the bracket is installed, you can then fine tune the position of the axle with the panhard bar. There is also the option to remove the drop bracket if you already have one or do not want it.
From the testing we have seen, 3/4 is working really well. SteezeMcqueen is running the 1st set of these and wheeling the crap out of them and they are holding up great!
Any chance of you guys ever carrying the Poly bushings for the Rear Link kit?
Are you looking for poly bushing for the stock links or for this kit? This kit already has poly in the bushing end. If you are looking for a link that has poly in both ends, we do not have those. The reason is that poly is a lot stiffer than normal rubber so it will not allow the axle to move and flex as much. This is why we are doing a heim on one end with these links and Johnny Joints with our non adjustable links
Oh ok gotcha.
I was looking to replace the stock rubber bushing with Poly.
I guess i'll have to do some measuring and research to get this done.
Thanks for the response
