green, i htink. the resvoire is darkish so its really hard to tell. still rated for 35 below which is important to me living in Montana.
but if I do a flush I was curious what was recomended.
First, a 50/50 mix of ANY color ethylene glycol coolant will protect to -34°F, even polka dot. Color only has to do with anti-corrosion technology.
Our trucks (EDIT: 3g's '99+) were born with Toyota Red, an IAT (inorganic acid technology) with phosphates and without silicates. With Toyota engines, phosphates are good, silicates are bad.
Toyota has now switched to their pink p-HOAT (Phosphated Hybrid Organic Acid Technology) Super Long Life full-strength stuff. This is already a 50/50 mix and protects to the same -34°F.
I think cj80 overstates the color switching issues. I had my dealer do the major services at 30k and 60k while I was in warranty to avoid issues. They took out the factory red at 30k and put in green. Then they took out the green at 60k and put in red again. I don't go back there any more, but they are probably doing all pink.
The red/pink and green technologies are antagonistic, but I don't believe 'tiny deposits' are going to destroy your protection. This probably more internet FUD, than reality. I have also done extensive reading on this topic. I flush real well, but I can use a hose because my mountain well water is extremely soft, testing below threshold for metals and calcium.
I am using Zerex Asian formula, which is a full-strength p-HOAT equivalent to Toyota pink and half the cost from NAPA, Amazon and others. Also good to -34°F.
That said, if you want to stick to green, keep your change interval at 30k or below and you will probably be fine. The newer green stuff is silicate free.
