Cornfed 1 inch spacer - no nuts received
CatahoulaManiac
I bought a 1 inch cornfed leveling kit spacer for the front only but it didn't come with the new nuts, I searched for low profile 10mm nuts but so far no dice. Anyone have a line on those or can confirm if the factory nuts will work?
ETA:
To help out people in the future, the 1 inch cornfed spacer will not work factory studs and nuts.
The nuts are standards 14mm, M10x1.25 thread pitch. I bought some standard grade 8 nuts of a lower profile, and will replacing factory nuts with these, a washer, lock washer, and a dab blue loctite.
ETA 2: Well the smaller nuts didn't work, they keep loosening up even with the loctite on there. Finally found longer studs from this website
https://wheelersoffroad.com/product/toyota/tacoma/1995-5-2004-tacoma-4x4-and-prerunner/suspension-steering-and-chassis/miscellaneous-suspension-parts/extended-length-top-plate-stud-set/
Hopefully this solves the issue. Sure would have been nice if Cornfed had sent the studs and nuts with the kit.
you dont need new nuts. My guys insisted on using the oem nuts vs the provided ones for my 2" cornfed front.
Awesome, I just thought there might be a chance that they weren't long enough with the spacer in there.
I have the 2" cornfed which is a spacer inside inside the coil pack, and another one on top. I'm pretty sure that i have the same spacer you installed + the inside coil pack one.
Got my leveling kit installed, and the stud isn't long enough to come up past the nut with the spacer in, is that how yours is?
I'm kind of wanting to try and do longer studs,having the studs below the top of the nut makes me nervous.
I used the nuts supplied with the kit. You want to have the studs to be past the top of the nut.
Yeah mine didn't come with them for some reason, went and bought some at advanced auto parts, put a washer on and a dab of blue loctite and tightened it all back up. I'm going to keep an eye on it for the next few weeks.
Then you'll be fine. I work for Loctite Inside Sales. They'll never come off!!! :)
Automotive OEM & Tier 1 Specialist
Henkel Loctite Corporation
One Henkel Way
Rocky Hill,CT. 06067
ghengiskhan
