Cornfed 3/2 Goodyear Duratrac 285/70R17 ??
skizmz123
I am wanting to get the cornfed 3/2 lift and put 285/70R17 Duratracs on my 05 T4RSport. My question is if I will have rubbing. Has anyone done this same thing or similar(same size lift/tire that has agressive tread)????
You MIGHT need to do a body mount chop mod. With new tires, you get more rubber. Front tires might rub the body mount. I have 3/2 cornfed but with old tires (less rubber). I am OK now. I will do the "chop mod" before I get new tires.
I have the Cornfed 3/2 with 285/70/17 tires on my Runner.
You will need to trim the inner fender well lining and molding closest to the firewall as well as either trim or push the lining in at the front.
Remove the mudflaps as well - no chance in running them.
I didn't make any modifications for the rear and don't have any issues.
I'm running 1.5" spacers also and that's what I had to do. When turning sharp, I still get a bit of rub on the plastic, but don't really care anymore...:lmao:
Hope that helps.
Hope that helps.
Do you have body lift? I have 1 1/2 body lift. Inner fender is fine with me. I am worry about the body mount part with full rubber.
