Cornfed and bodylift set up
ROOFGOOF
Well, as soon as tax returns come back I plan on doing this possible set up. My intentions are very limited off roading. The looks are what I want.
Cornfed 3 inch lift, but I see they only have a 2 1/2 for the rear. Will this give the sag look to the rear end ???
Will this cause any stress on the CV's ?? Any modification needed?
Will this also cause any drive line issues??
I also wanted to do the Roger Brown one inch body lift.
Anyone with the above lifts that can provide input is greatly appreciated. THANKS.
Pictures are a plus too.:cool:
i would suggest the RB 2" bodylift, it isn't much more $ and is pretty much the same difficulty. as far as the spacer setup, i am not using those(decided on new coils instead) but i would suggest using the same front and back, also a 'front diff drop" is a must. anything 2.5" or more really needs it or you will probally have front cv issues.
-Matt
i just ordered all the parts for the same setup. i went 2.5" cornfed all around and the RB 1" body lift and cornfed diff drop. Everything but the body lift is here and should be in in about two weeks. I'm also ordering up a Sonoram Steel panhard drop bracket. Not many people do this but it seems to be a must. I'll post up some pics once everything is installed.
Also, what size tire are you looking to run? You may not need some of the parts you want depending on tire size.
I am running 265 75/18's and plan to keep that tire due to MPG issues. Hook us up with some before and after pics when you get done.
I plan on doing a BL of 2 inches and 3 inch suspension.
HELP
If anyone has done a roger brown 2inch lift please advise... I was wondering what you had to do with the spare tire release??? Are you able to still lower the spare tire using a 2inch lift or did you have to fabricate a new part to fit in the lowering hole.
THANKS in advance.!!!
BillM777
