Correct Position of 4Lo Shaft Half Gear
Izlu
Does anyone know a correct position of 4Lo shaft half gear for Hi range? I read nearly all 4Lo related threads but haven't been able to find any info on this.
Found this pic in a training guide uploaded by [MENTION=66389]BlackWorksInc[/MENTION] which clearly shows the 4Lo shaft and the half gear in Low range.
I assume that if I put the half gear in Low range and manually rotate the half gear to the other end it will be a correct position for Hi range. Is that correct?
I'm not sure how accurate a representation that picture is to real life unfortunately. :(
Im not sure if that IS the correct position for hi; however, it is only logical that the lo gear would move that way, as the spacing in the case (based on pic that [MENTION=66389]BlackWorksInc[/MENTION] said may be inaccurate, so dont take my word for it) seems to allow it to only move in that manner.
Tl;dr: im not sure if that's it, but it makes logical sense.
charlesz
