correct shocks for 3" lift ???
scubad86
guys i have just bought the LC springs for the 3 inch lift but i know i need bigger shock but what would you recomend, if you have a link to a site eve better. also as these are bigger i will need some sort of seat for the springs to fit snug in any ideas
depends on how much articulation your going to have. I determine what I'm gonna get by flexing my truck out until its about to pull a tire; measure the distance between the 2 mounts so you'll know the minimum fully extended length you'll need then measure the compressed side mount to mount and youll know what the minimum compression needs to be. choose the brand you want and match up a set based off your measurements
