Correct Tundra coils?
bak3rme
Senior Member
I got a set of tundra coils in my hands, just want to see if anyone has them or installed them before. They are not the blue/blue blue/yellow and the only search that came up was one thread about the color code i got...
anyways they were off a 2004 toyota tundra TRD . not sure 2wd or 4wd but the ad was here :
Want to sell AZ: Lots of stuff. Wheels, tires, suspension, shocks, - YotaTech Forums
anyways the color code on these bad boys were blue/blue green/green.
any info on these?
i would pass... they gotta be the y/y y/b... you wouldn't want to get everything you need for your lift only to find out these won't work once they're on the truck.
Tundra TRD Coils. Left, 48131-AF100 (Yellow/Yellow). Right, 48131-AF090 (Blue/Yellow)
The TRD coils fit:
4wd, access cab, w/off road pkg. 2000 - 2002
2wd Access cab 2003 - 2004
4wd Access cab Left 2003 - 2004
well i have these currently in my hands . just want to know if they will lift 2'' or not.
if not i might re-sell and get correct one
The only truly tested Tundra coils are the y/y y/b. I want to say try them out because I want to see the results, but I'm not sure what kind of lift you will get. If you do put them on, please have before and after pics and measurements.
The y/y, y/b are the TRD Tundra springs, and the reason they are recommended for this is they are progressive rate, whereas the other tundra springs I believe are linear rate. The non-TRD springs may provide the same level of lift, or close, but they will ride much rougher.
If they aren't the right ones, they are likely the wrong ones.
i doubt it'll give him the same amount of lift... probably 1" max.... i came across a thread a few weeks ago but i can't find it now where someone took the non trd springs and installed them and gave him about a 1" up front... i've tried finding it but i can't, i only remember it was a forest green runner. but i'm with SCRunner on this... it'll be good to document this.
05 Step Side, 2X2, TRD Sport Package
Drivers side front coil Green/Green
Passenger side Blue/Blue
Tundra TRD Owner Roll Call... PLEASE READ!!! (coil springs) [Archive] - Toyota Tundra Forums : Tundra Solutions Forum
thanks man.
so i know it was from a Trd tundra. wasn't sure 4x4 or not. it wasn't a double cab either so this makes it clear that it was a tundra 2wd TRD package. so now...i think i will put these on with 4runner tophats and see how they ride.
and I will take before and after measurements
charlesz
