Well, I bought a 1997 4Runner with 149,987 miles on it a month ago. According to the used car salesman it was well taken care of, and it really did look as such. However, about 2 weeks after I got it the check engine light came on...greaaat.
I grabbed my dads ODBII code reader and it spit out the following codes;
P0131 Sensor Circuit Malfunction (Bank 1 Sensor 1
P0133 Sensor Circuit Slow Response (Bank 1 Sensor 1)
I'm going to go look the codes up right now, but does anybody have an idea what might be the culprit?
On another note, I have been driving the car around for about 3 weeks now with the check engine light on after I found what codes were causing the light to go off, and have not noticed any hits on performance or anything like that. However, today I started having some issues with the engine dying at idle speeds. The engine will start up and rev just fine, but whenever I let off the gas, the engine will die after slowly decreasing in RPM. Could this have any bearing on the two before mentioned error codes?
And while I'm here posting, I think I'll mention 2 other issues that I have been toiling with. First of all, the A/C button sometimes does not disengage. The button itself works fine, but the A/C light will sometimes not go off after the button is pressed. Pressing said button off and on several times helps the issue.
Secondly, the lights on the console on the A/C portion will always be off. If I hit the console they will come on. I'm hoping this is a connection issue more then anything else.
