masphx
Hi,
Bought my new 1998 5speed 4x4 4runner two weeks ago. Since then put just under 1000 miles on her.
Just some questions on some things...
-Tacoma Whip Mod. Can someone link me to the best guild to converting broken power antenna to the whip antenna. If I need parts should I get then at the dealership?
-Suspension. Truck has 169,000 miles on her and all suspension components look original. I'm sure shocks on other things should be replaced since the truck seems pretty 'bouncy' and rocks when I come to a stop. PLMK what parts I should replace and is it a DIY job or better handled by a mechanic (I'm simi-handy around cars but never done a suspension job)? Just looking for a basic replacement of suspension here. Not really looking to lift the truck at this time. How much should these parts cost?
-Noise - With windows down and engine engaged with the 5speed transmission truck makes a 'light metal' sound for a split second around the 2500 rpm spot. I have revved the engine while not engaged with the transmission and no sound. This sound does not always happen. I would say about 40% of the time. If I get close or stick around the 2500 rpm zone the sound will stick around a little bit longer. My question is what could this sound be and should I be concerned? Should I check for anything? I know this is a sound question and I'm even having a problem describing the sound. I might youtube this and post the link here if that helps.
-5speed - while going slow in 1st gear should it be easy to 'slip' the transmission out of 1st and into neutral w/o pushing on the clutch? This happened one time while I was resting my hand on the stick.
-Paint- Color of truck is white and paint is mostly original from 1998. I think the truck sat outside in Dewey, AZ for awhile and paint is faded. It's even chalky in some spots. Can I do anything to restore the paint a little? Does not have to be perfect since it is white but would like to stop anymore damage from happening to the paint. Would a simple wax job help or will the fading and chalking continue?
-roof rack- Already have the OEM rack but think a aftermarket one would look better. What is the 'best' rack to get in your opinion. Please inclued costs and pictures if you could
-fuel filter- is this an easy DIY job? Costs and where I should get the part if so?
I know, its a lot of questions so thanks for the read and reply. It's cool to reply even if you only have one answer.
Thanks,
Mason
Here is a picture of the 4runner. Running boards have been removed...
Thanks,
Mason
