Cracked valve cover
NWFLBowhunter
When I bought my 97 4runner back in December, it had a valve cover leak around the front bolt on the drivers side. The po said when they replaces the seal, they didn't replace the grommets. Well I cleaned it up when I got home and discover that the cover was cracked completely across where the first bolt goes probably from over torquing it. So, would you trust a salvage valve cover or should I just buy a new one? The leak isn't bad, but I have the time to fix it, so it's time.
I've got the same problem and I'm going to go ahead and buy a new one as opposed to salvage. My thought being, the salvage one is just as old/weak from being torqued. Those corners or "ears" can easily crack if someone is overly heavy handed with a wrench.
thanks Doc...as soon as I take care of this weird hesitation/surge issue I'm having I'll have to hit the road and make the drive! what would you be asking for the pair?
The only reason they crack is from being massively overtorqued. They are either broken, or they aren't. Cast aluminum doesn't get "weak" in this case. I would much rather use a used one at 1/4 the price of new, and just make sure to properly torque it down. Toyota does have a torque spec!! People don't bother with the spec though and just since them down until they crack.
It's not a design flaw, it's an "I didn't follow the repair manual" flaw.
I didn't say there was a design flaw..mine came that way. the previous owner didn't follow the repair manual ..I'm very familiar with torque specs.
I know you didn't. Just stating in general. I have heard many people complain about the design, and while its true the design could have followed others that had the ridges on them, they didn't but they do have a torque spec. So my point was previous people damaged it by being careless, ergo a used on that isn't cracked will be just fine and perform the same as a new one.
Jb weld
I did my valve cover gaskets couple months ago and errrr geramn torqued the corner...crack....
Cleaned it up jb weld, little sanding...bam what!!!! No more crack
Jason
charlesz
