Crazydubman's 97 limited runner build
Next up was the front end has needed a service for a while. During the last Death Valley trip I noticed the passenger side wheel bearing starting to whine a little. I knew with the previous wheel and tire setup that the bearing were going to see some significant stress (very heavy double beadlocks and 1 3/8" adapters). While I was in there and while the hubs were apart I wanted to replace all the wheel studs as they had been cut down slightly when I had the adapters and one of them had snapped at some point. Dropped the spindles off at a local machine shop to have the work done. I don't have room for a press at this point so doing it at home was a no go. Went with all new OEM parts and all went together smooth.
I decided while the spindles were off to take advantage of the "While your in there mentality" and do the following reinforcement since the front end would not be torn down this far again for some time.
Total Chaos spindle gussets - Part# 59697
Total Chaos upper control arm/shock tower gussets - Part# 59650
Total Chaos cam tab reinforcements. - Part# 59960
Whiteline lower control arm bushings. - Part# W53377A
Whiteline bushings went fairly smooth except for the known headache with the steering rack and the rear alignment bolts. Thankfully there was no rust and the alignment bolts just slid right out without fuss. One of the bushings was completely separated and you could spin it free in the outer sleeve and rock it around. All the others were partially torn or cracked. No pictures of new bushings in place with the arms off but you can see them in the final assembly picture at the bottom.
The upper control arm gussets I will say were a lot of work. Had to trip out some of the inner fender for clearance and need to modify the rubber covers now for fitment. word of advise would be to add a shim where the bushings sit while prepping for welding. Reassembly was a challenge with the new space for the bushing being fine prior to welding and just a hair tight on reassembly. had to use some ratchet straps to put tension on the new gussets in order to get the upper control arms back in..... Oh and made sure you don't forget to get the brake line through the bracket BEFORE you weld them in. Missed that step on one side and had to bleed the system because of that.
Spindle gussets went in well. Just a little grinding for fitment and made sure the top had needed clearance around the upper uniball mount to keep clear of the coilovers. (Some have said the ran into spring clearance on that upper section at full lock droop) Here is a shot with the new wheel bearings and studs installed as well.
Next up was the alignment cam tabs. This took a bit of work due to the access around the CV joint and steering rack. I ended up buying an air reciprocating saw and air chisel to help and they were worth their weight in gold. Could not have gotten a grinder in where I needed to.
Once all of that was done, I was able to get it all reassembled and back together.
Initial test drive was as expected. Much more solid front end and quiet. This took quite a while with having limited time to work on it. Would not want to do it again, but it was definitely worth taking care of it all at once.
Well folks, the time has come for me to make a tough decision and unfortunately that decision is that I will be selling the 4runner. It has been a tremendous journey over the years building it to where it is today. So many good memories with the family and with friends wheeling and camping with this thing.
It has come time where it is no longer large enough to suit my families needs so it needs to be sold to have cash to put down on the next family camping/exploring vehicle. Fitting my wife, 7 year old son, and two mid size dogs with gear for anything more than an overnight trip is no longer a comfortable endeavor. Unfortunately that means its time to get into something larger and more comfortable for the long haul.
I am planning on selling it as equipped for the right price including lighting, winch, hilift, CO2 tank, etc. Would like to start fresh I guess and see where life takes me and my family.
If interested or know someone who is, please keep a look out for the for sale post in the next couple of days. I'll post a link here as well so its easy to find.
Thank you all for keeping an eye on my build over the years and the amazing support you all have shown. This will always be the best forum/platform for the comradery and discussion that I have been a part of.
Cheers
<a data-flickr-embed="true" href="https://www.flickr.com/photos/142430248@N04/51498237314/in/dateposted-public/" title="IMG_E9839"><img src="https://live.staticflickr.com/65535/51498237314_77dd5482f1_c.jpg" width="800" height="586" alt="IMG_E9839"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/142430248@N04/51496727717/in/dateposted-public/" title="IMG_E9836"><img src="https://live.staticflickr.com/65535/51496727717_b015b92152_c.jpg" width="761" height="800" alt="IMG_E9836"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
I enjoyed reading through your build thread when I first started on this forum. It's sad to see you go, but hopefully the next owner will enjoy this as much as you did. Any idea on what the next platform might be?
Thanks Bad Luck.
As it will need to fill the spot of my current work vehicle for the next 5 years, I have been looking at new F250's. Hoping for a 2022 lariat short bed with the new 7.3 gas motor. I currently have a 2017 F150 XLT at have had no issues at all with it other than the wife complaining on long trips with the cloth seat comfort. With the cab size being the same on the F250's and the payload/towing increased sizably, it would be a better vehicle for the long term with plans to get a camper at some point for longer family camping trips. Build will likely be fairly basic. (Still has to function as a work vehicle for now) Carli pintop suspension, 35's, lighting, winch and storage/racking/shell to mount our James Baroud Evasion XXL RTT when needed. Just want to be able to get out there and explore more with the family in a little more comfort and space.
If I end up wanting to get back into crawling more, I will likely look at alternate toys to tow out to where i'm going.
I do outside sales for a local CAT dealer.
If my work didn't reimburse some of the monthly expense there is no way I would be able to afford it outright. I would have to put down my F150 as a trade in plus a good amount of cash to get payments that were reasonable.
Also working to sell my 79 Vokswagen diesel rabbit as well to help.
Vehicle choice is mine for the most part (American Mfg, 5 seater, non luxury or specialty, etc) but work pays a fixed amount. A Superduty is just a vehicle I have wanted for years and with my families changing needs, it makes sense to utilize my work's reimbursements to help offset the payments.
Not ideal but it will be nice to not have 4 cars including the wife's and the expenses that go along with each right now. (Insurance, registration, space, etc)
Looking for a fresh start really.
Well folks it’s been a hell of a ride but it’s time to let the 4runner go.
Here is the for sale thread for those interested.
https://www.toyota-4runner.org/for-sale-vehicles/301603-fs-3rd-gen-1997-limited-4runner-built-locked-geared-armored-$18-000-brentwood-ca.html
delislerebecca
