I have found the culprit of the noise, it is where the upper and lower plastic pieces comes together. When you go over small bumps or uneven surfaces in the road I get the noise.
I silicone sprayed it but it really did not work.
This is the area or a bit to the right that makes the noise. How do you remove the panel to fix it? I tried turning those little crank wheels with my fingers, but no go.
Anybody know what the hose that is not connected to anything on one end that is in the fender??
Thanks, madmmac
Thanks, madmmac
