Quint said:anybody here tried the cross drilled slotted rotors from wheelers off road? I am currently waiting on a rear set with carbon kevlar pads and wanted to know what people thought.
Don't waste your $ on drilled rotors, oem drilled as used on Porsche are not drilled anyway, the holes are cast in then touched up w/ to have a chamfer Additionally the substructure of the rotors is designed for it. They have more of a tendancy to crack than solid or slotted anyway. Most guys that track are abandoning the oem drilled to adopt slotted these days(where they are available)Quint said:anybody here tried the cross drilled slotted rotors from wheelers off road? I am currently waiting on a rear set with carbon kevlar pads and wanted to know what people thought.
That is correct tooCasper said:problem with drilled and slotted rotors is really that you are going to have less surface area for the pad to contact and with that, you loose performance and with less mass, you have less area to dissipate heat from.
Axxis does have a good line of street performance padsCasper said:I have the Axxis ULT pads F+R and Stoptech stainless lines and this setup is the best I have used in numerous cars.
While rotors can warp, by far most instances of rotors diagnosed as 'warped' is really uneven pad deposition.1999sr5 said:my dad used to warp his oem rotars all the time. not to say i condone his style of braking haha but his drilled and slotted rotars have held up so far.
