Cruise control and clutch pedal
MaukaRunner
I had a problem with my cruise control not working. Was initially intermittent and within almost a year it became more frequent and frequent. One day while driving it was working fine and pressed in the clutch to coast downhill. When I got to the bottom I tried engaging the cruise again and it didn’t work. Then it dawned on me it might be the clutch pedal.
I used my toe and pulled up on the pedal and it moved 1/2” to an inch.
Because the clutch pedal does not come up all the way the cruise control won't engage.
I just use my toes to pull up the pedal and all is fine now.
Well you haven't asked how to make the clutch pedal return properly, so I am reading this as you are pleased with your fix. In which case, nice work. Now if you would like to know how to fix the problem properly feel free to ask and I'll tell you.
Actually after changing my ignition housing and greasing the return spring it seems to be returning all the way but since I might have missed something please post the info for the proper fix.
I'm sure others would like to know too.
Thank you,
IThen it dawned on me it might be the clutch pedal.
I realize this is an old post, but I'd like to know, if the OP is still around, how that solution is working for him.
I found this thread, when I was first looking for solution, but the solution wasn't listed - which makes the thread less useful for those who come after us.
What did the OP finally do as a solution?
Knowing what I know about the classic problem with the clutch pedal squeaking and with it sticking in the down position (needing to be pulled up with your toe), I'm pretty sure neither the ignition housing nor the grease is any sort of long term solution.
The long-term solution is discussed, in detail, over here, in case someone else comes here looking for the solution to the stated set of symptoms.
Thanks for the link on the long term solution. I've read it in the past but I haven't had a problem with the clutch since I greased it.
My 4runner has 178K miles. Changed the clutch, pressure plate, master and slave out in '12 at about 145K miles so that may be contributing to the pedal returning smoothly. It still does make a squeaking noise but I don't have to do anything to make it return all the way.
You can also adjust the play by removing the lock nut and turning the rod. You want the slightest amount of play left in the pedal so that it's not engaged but not enough that it flops around.
I'm impressed Toyota had the foresight to disengage cruise when clutch is down.
It's interesting that there is a switch at the bottom of the clutch pedal travel, and another switch at the top. The bottom, I think, is for starting, and the top is for cruise control.
If you have the same problem that almost everyone else has, the grease can't do anything but mask the problem for a while longer.
Your P bushing is most likely missing, which means you have metal on metal, which is what caused the internal cabin squeak most likely. Putting grease on that contact doesn't stop the spring from destroying the clutch pedal metal tab.
It's easy enough to tell if you snap a photo using your cellphone camera (it's too tight to get your head up in there) or if you use a mirror.
Inexorably, the spring is rubbing against the metal of the clutch pedal, which ruins both. So you have to then replace the $100 clutch pedal and the $15 spring eventually.
Here's a picture from last week of what the metal-to-pedal looked like when I finally figured out where I needed to look.
All the grease in the world isn't going to change the fact that, without the P bushing, eventually, the angles will change (ever so slightly every day), until the spring will kink, and bust one of the two Q bushings, and at that point, your pedal will stick due to the increase in friction.
If you replace the P bushing once every year or two, this doesn't happen.
If you replace the torsion spring with a linear spring, this doesn't happen.
But if all you do is grease it, it will happen (there's nothing to stop it from happening).
Here's a picture, many years after the P bushing failed, where the Q bushing finally failed:
223909d1477078433-5-speed-clutch-pedal-sticks-floor-morning-three-days-row-torsion_spring.jpg
The problem with the squeak is that eventually it will cost you a new pedal, which is the most expensive part.
223804d1477022510-5-speed-clutch-pedal-sticks-floor-morning-three-days-row-pedal_stick.jpg
If you're going to stay stock, then you have to check the P bushing once a year. The check is simple, if a bit uncomfortable.
1. Pull back the driver's seat and lay the back down & raise the steering wheel to give you as much room as possible (it's never enough).
2. Lie upside down with your head looking up and snap a photo of the center of the spring where it touches the pedal. You may have to snap about 20 photos before you get up and over the bracket enough to see what the spring contact with the metal pedal tab looks like.
I'll bet yours looks like everyone elses, which means you now have to buy a new pedal. If you're lucky, your P bushing is still there; but I'll bet you're not that lucky.
223808d1477027635-5-speed-clutch-pedal-sticks-floor-morning-three-days-row-clutch_pedal_p_and_q_bushings.jpg
Notice in the photo above, the lack of a P bushing cost the owner the price of a new pedal, and the lack of the Q bushing cost him an additional amount to replace the bracket assembly.
The moral of the story is this:
a. Everyone should realize their P bushing is likely toast.
b. The squeak is the first sign, but if you don't replace the P bushing at the first sign of the squeak then it is too late.
c. If you try to replace the bushing using the OLD worn pedal, it will break in a day or two (almost always, as noted in the retrofit photos below).
223924d1477080214-5-speed-clutch-pedal-sticks-floor-morning-three-days-row-grumble.jpg
Thank you for that suggestion. When I was testing it, it seemed to engage very high up, almost 3/4 of the way up in the travel. It's not my 4Runner; I'm helping out a non-technical family member who owns it.
The clutch was replaced probably 50,000 or more miles ago, so, it's certainly worn but still engaging (it's not slipping).
Where in the pedal cycle should the clutch engage?
You got it right with the switches. The clutch does engage fairly high up, but you don't want to have to mash the pedal to the floor just to shift gears which is what started happening on mine before I adjusted the pedal height. Play in the pedal is not your friend by any means in any pedal, whether it's the clutch, brake or gas. The FSM will have very specific amount of play and travel for the pedal if you can get your hands on one.
Awesome writeup!
Sometimes my cruise control doesn't want to engage either, but when I tap down lightly on the clutch pedal a couple of times (really gentle, hardly pressing it down so it doesn't disengage) that also seems to help! It sounds stupid, but it works on mine
PRWhite
