riverrat44
Hi All,
On a recent trip I could not get my cruise control to work. Not sure how long it has been out. The indicator light works, and does not blink.
One post I found in a search here said it might be a fuse. If so, which fuse would it be? I checked both fuse boxes and did not see one specifically for the cruise control, but I may have missed an abbreviation. I looked pretty close and did not see any that were burned out, although I did not pull every single one to check.
If it matters, my rig is 4x4, 3RZ 4 cyl 5 speed. The last maintenance I had done was having the diff fluid changed to synthetic, not sure if they could have knocked a wire loose then. I also have some lamps for the heater controls that are out, but they've been that way since before the cc quit working.
All help in diagnosing this will be appreciated!
