Cummins 2.8L in a 3rd gen?
theriddler
Is anyone else considering doing this besides myself? I work for Cummins and would love to have one, but until now they haven't offered an engine i was interested in for a Toyota. I'm about to buy a 2002 Sport Edition 4runner with a bad tranny but it got me thinking if i should just pull the engine and start mapping out a plan to make the diesel swap happen. It would be great to actually drive something i want to drive to work everyday instead of what i have to drive (a high mpg car). I guess i'll wait and see what kind of transmission adaptors will be available but i'm guessing the initial offerings will be for Jeep conversions. Price for the engine is around $7000 from what I've been hearing. Sounds like a lot but i could have diesel powered 3rd gen for around $10K if i did the work myself. Is this the wrong vehicle to be considering this or would this be a better idea for a Land Cruiser? Thanks...great forum by the way!
https://cumminsengines.com/repower.aspx
Wow. I had no idea. That looks like a solid option. I really like the universal wiring harness. Seems very straight forward and well thought out. Curious about trans adaptor offerings as well.
I work on Cummins too. I was thinking the same, bell housing not a big issue if you guys are worry. AA will have anything you need to make it fit! Just the investment is it worth it?or the 3.4 good enough.Plus I like to keep everything Toyota
Maybe I'm biased because I have a 1KZT-E in my landcruiser, but you can now start picking up these engines from JDM importers for under $3000 easily including box, transfercase, ecu ect, and they will bolt right in and wire up fairly easy as they were a designated engine around the world for these trucks.
These engines are also far more refined as far as drivability, noise and vibration goes compared to those cummins motors. It also gives you plenty of spare cash to play around with mods to the engine if wanted.
Just my 2 cents
In purely practical terms, I can't think of a single good reason to spend 10k on putting a diesel in a 4runner. You'll never recoup that in fuel savings, and the new cummins' reliability hasn't been proven where the 5vze has.
Cool project for sure, but you could have a good running reliable 3rd gen for much less.
But if we all only ever thought in practical terms, the world would be a boring place.
Do It! You could call it the CumRunner
Just my 2 cents
The R2.8 is a far cry from the 4bt that you’re probably thinking of. The reviews praise the motor for being very quiet and refined.
Not to mention that gray market import motors aren’t legal for swap in many areas.
The 1KZ is pretty damn awful lmao. That 2.8 Cummins might now be as proven but it sure as hell will be way more modern.
considering that it is a new engine, the hp (161hp) and torque (267 lb-ft) aren't that impressive.
btw, what's the difference between aftercooled and intercooled?
In thise usage, theyr'e the same thing.
I think they're just being technically correct.
An intercooler is supposed to be used for a cooler used between various stages of compression, before the compressed air is delivered to the destination (the engine). If you had a couple of turbos in series, or a turbo feeding a supercharger, for example.
An aftercooler performs the same task, but it's after all the compression has taken place, before the air is delivered to the destination.
I guess most people just started calling aftercoolers the wrong thing at some point, and in some sense if you include the engine as part of the air flow system, it is in the middle of the process, not at the end.
Also, the HP and TQ numbers are probably rated at a low boost setting, so they can warranty the engine for years and XX,XXX miles. I'm sure people will be modding them in no time. 4BT's only put out around 100 hp in 'stock' form. You can't expect Cummins to put out a 40 psi tune on these things.
Tx470
