Custom Rear Platform for 5th Gen
StickToRhythm
Junior Member
I recently finished a custom rear platform to create a level surface with the rear seats folded down for sleeping and provide some storage underneath for recovery gear and whatnot. After reviewing a bunch of examples of what others have done on this forum and elsewhere, I came up with my own take on the design and solicited the help of a generous friend who is really into woodworking.
It is made from 3/4" baltic birch plywood with a top layer, a second layer, 3 supports, and a trim piece. We used dowels to connect the pieces comprising the top layer and second layer. It includes two large doors with piano hinges, strike plates, and locking flush mount paddle handles. There are also 3 rows of L-track for a flexible tie-down system.
I decided to have it coated with Rhino Lining (similar to LINE-X) to provide solid protection and make it look more stock/professional, despite the additional weight. This also added some complexity and uncertainty with the measurements to accommodate for the thickness of the finish.
Toward the front of the vehicle, it is connected to factory locations with bolts and large washers in countersunk holes. Toward the back of the vehicle, I initially tried securing it with turnbuckles and the factory tie down locations, but I didn't like the way this worked and ended up using L-brackets and self-tapping screws to attach it to the vehicle and keep it secure.
I've very pleased with the result; it turned out pretty much just as intended. Hope this provides another good example and some ideas for anyone looking to build their own.
more pics
and some more pics
tell me more abbot your subwoofer!
Hi - The sub is an Arc Audio A10 powered by an Arc Audio X2 1100.5 in a custom enclosure. It's one of the shallower 10" subs you can get, so it fits ok in this location. This was my second audio system built by Simplicity in Sound. The sub box took a lot of custom fab because there wasn't a factory sub, but it turned out great. A single 10" at 500W isn't going to be particularly powerful given the large interior volume of the vehicle, but it still bumps and blends nicely with the front stage.
If you're interested in the full audio system build, here's the build log.
Great build! I opted to just have slip in doors without latches because I was worried about sliding gear around and getting caught on them. I installed tie down rings instead of the strips, but I like the way the strips look. I decided to go cheap... so far hasn't caused me any problems, but I don't use them a ton. The last offroad trip, everything stayed where I strapped it, so it's successful, but not as aesthetically pleasing.
I've done woodworking enough to know how to skate by (my build) and that having a buddy with the tools and time is worth tons!
beautiful work but a bit more work and less space for stuff. i made myself a 3/4 inch plywood platform only holding it down in the corners. i have a 3rd row seat i had to remove. I'll send the pictures later.
if you ever sell your sub-enclosure, please...PUHLEEEASE let me know lol.
i took out my 12" alpine r because i need the space. I miss having a sub :(
Would like to see your own thread with your take on the 3rd row delete
I know it looks shallow looking at the platform itself, but it provides about as much storage depth as you can get while creating a level surface. The supports sit on the "rails" of the side panels which are elevated a bit above the bottom of the vehicle, so the storage depth actually goes below the bottom of the supports.
I also removed the padding on the back of the carpet before putting it back in to reduce the thickness and maximize storage height. It yields about 3.25" of height (somewhat variable since the bottom of the vehicle isn't perfectly flat).
Beautiful work, really nice. I did something similar but with slide outs since i needed a table/work space more than storage.
AndiGarage
