badhabt
I'm in t he middle of replacing the driver side cv axle on my 88runnr (first time). I am ready to seperate the tie rod end from the knuckle arm so I can swing the wheel hub out to slide shaft out. So I removed the nut (and pin)from the TRE. I used a rubber mallet to tap on the stud, but it didn't budge. Do I need a pitman arm puller to slide the tie rod stud throu the knuckle arm? I've heard using a pickle bar will wreck ^&*% up.
Any tricks, advice anyone could share?
