Cylinder 4 goes to Coilpack 3?
I have a misfire on cylinder 4, Just wondering which coil pack it goes too. I think it's cylinder 3's coil. Just checking?
Cylinder 4 goes to Cylinder 1's coil.
<br>
Hopefully its a bad coil pack, I taking it your going to move it and see if the miss follows? I had a miss on cyl 4 and it ended up being a valve i$$ue
Here's another view from a recently posted PDF of our 5VZ-FE engine:
Coil_routing-1.jpg~original
Note that there are only 3 ignition signals, and each fires two plugs simultaneously. Not sure why they didn't put lightning bolts from the paired cylinders but that's how it works. That's why you need dual-tip plugs.
