Cylinder not firing RE- 6 Cyl Engine
MattinLA
The engine is shaking, it's hard starting, UPDATE - the starter is BAD, when I started it it was grinding away because bendix-solenoid is not retracting! Whew! Ok, is it possible for the bendix to be abnormally engaged to the flywheel AND the car moving at speed, and there is NO grinding? In that case, the starter would be a LOAD/ DRAG! Does this EVER HAPPEN? My car was shaking! Starter BAD, is this a coincidence?
Somebody DO something!
LoL. Well I'm typing .. hope that helps
Dude if you can afford a diagnostic then take it to get the codes read. Could be a lot of different things but codes would help.
Also, how many miles?
Philthyphilthy
