Dash area fan noise help
mnormand
2004 4R 4x4 SR5
Could use some help here please:
I'm getting an unusual whirring type noise in the right side dash area. Already changed air cabin filter and checked squirrel cage and fan motor area for leaves etc.
Before I start tearing things apart is there another fan motor of any kind under this dashboard? noise is very obvious and not normal. I am also going to pull fuses to kill the fan and try to isolate the noise first.
It's probably the blower fan going bad, there's nothing else under there. I'm pretty sure its just a few screws on the bottom to remove it.
-E
Get a mechanics stethoscope and pull the glove box (5 or 6 screws) and listen to anything around the ECU. There is a blower and some A/C plumbing in there. Very likely blower fan bushings or bearings going bad.
PIA....
AIR CONDITIONING: BLOWER UNIT: REMOVAL
REMOVE CONSOLE UPPER REAR PANEL SUB-ASSEMBLY See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Removal
REMOVE CONSOLE PANEL SUB-ASSEMBLY UPPER See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Removal
REMOVE CONSOLE UPPER PANEL GARNISH NO. 1 See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Removal
REMOVE CONSOLE UPPER PANEL GARNISH NO. 2
REMOVE CONSOLE BOX ASSEMBLY REAR See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Removal
REMOVE COWL SIDE TRIM BOARD RH See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Removal
REMOVE INSTRUMENT PANEL UNDER COVER SUB-ASSEMBLY NO. 2 See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Removal
REMOVE GLOVE COMPARTMENT DOOR STOPPER SUB-ASSEMBLY
REMOVE GLOVE COMPARTMENT DOOR SUB-ASSEMBLY See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Removal
REMOVE INSTRUMENT PANEL FINISH PANEL LOWER NO. 2 See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Removal
REMOVE INSTRUMENT PANEL REGISTER ASSEMBLY NO. 2 See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Removal
REMOVE AIR DUCT NO. 2
PIA....
Because the blower is on the bottom of the stack, I think you might be able to get to it from underneath, without removing anything other than the glove box lid. Not certain, though.
-E
Dash Fan Noise
I had a problem like that last year and finally discovered a mouse had built a nest in fan cage and around it. Chewed up the cabin filter as well - bits and pieces all over the place. Took a few cleanings to get it all out and then I sprayed a whole bunch of lubricant (non greasy type - can't remember the name) in the top of the blower cage where the pin is. Fan purrs now, but it drove me nuts for a long time.
Love camping - Hate mice!!
My two cents.
Cheers,
07 V6 Ltd
lindwlson982
