dash lights came on during towing. ??
juneau92
Dash lights came on during towing. Huh??!!
Last week we were towing our trailer up a long 6% grade, from the desert to the mountains. Outside temp was 103 degrees (Arizona). Being with the holiday, there was a lot of traffic on the road. I was in third gear going up this part of the grade, when I got stuck behind a very slow moving semi. I couldn't get around it because of traffic, and having lost my momentum. I dropped down to second gear, and we were going I think about 30mph, or so. Dropping to second kept the rpm rate between 3-4K, which is needed pulling a trailer uphill, especially on a hot day. My 4runner has been up this grade before twice pulling the trailer, never a problem, and no problem this time either, except for us getting stuck behind this slow moving semi, and having to drop to second gear, and then the dash lights coming on.
Okay, so we're making our way up the grade, when I look down at the dash, and the VSC TRAC, SLIP INDICATOR, and and VSC OFF lights, all three, are illuminated. Huh??! Kind of scared me a little, thinking something wrong with transmission, or what else, I didn't know what to think.
The 4Runner was pulling the trailer just fine (see my sig for photo and description of trailer). Trailer is well within towing capacity of V8 4Runner, weighs about 5500# loaded, so should be no problem there. Other than the dashboard lights, the 4Runner seemed strong, and sounded great!
After we reached the crest of the grade, since the 4Runner was going so strong, and sounded good, I thought I wouldn't stop, but instead keep driving, and see if the lights would go out, expecially after shifting back up to 4th gear, and speeding back up to 60-65mph, my usual towing speed.
Well, the lights never went off. So after about 30 minutes I saw I needed to get some gas, and I wondered if after turning off the engine while getting gas, and then re-starting it, the lights would be on or off??
Stopped, got gas, engine off. Started engine back up, all is normal, dash lights are out. Continued our trip of another 100 miles or so, camped 4 days, drove places each day, then drove home, about 500 miles altogether, with 400 of those miles being AFTER the dash lights had been on. No problems, 4Runner purred the whole rest of the trip.
Do you all have any idea what happened? I was thinking of taking it in to be checked, but I know from experience that it's hard to fix things that are not broken. What do you all make of this?
Thanks now very much.
edit: corrected a few mistakes.
I tow a camper with my 06-V6 runner (aprox 4,300 lbs under load) and I have not had any problem with any dash lights .......... However about a month ago I was driving home from work and I had a few lights on the dash come on ......... "What the ....." so I pulled over and shut her off and after I started the runner back up I had no more lights and the problem has not repeted itself so who knows???
My Dodge would do strang things like this all the time and I ran it for many miles without a hitch so ????
could have been as simple as a loose gas cap
I think when the engine throws any code the dash lights up like a christmas tree. My lights came on and when the dealer checked the code it was something to do with the fuel system pressure (can't remember the code or the full explaination). They reset the code and all is fine. Get the dealership to check the code next time your in for service....I wouldn't worry about it unless it lights up again
Re: could have been as simple as a loose gas cap
Thanks guys very much for the replies. Guess it's not much to worry about. Happy 4th! :)
I have an 04 V6. About a year ago the lights on my dash flashed and the truck studdered. I didnt think anything of it. Went to go to work the next day and all hell had broken loose with my runner. Needless to say definatly get it checked out. Luckily the warranty covered everything and about $13000 (not a typo) later, rental vehicle included, it ran great. Has run great ever since.
^Wow what all did it need? That's a big bill.....don't see those too often on Toyotas.
For the thread, I would also get the dealership to scan it whenver you have a chance, but if it's running fine it's likely nothing dire.
Bump.
$13,000! I agree, what the heck did your 4Runner need?
Suggest you get an OBDII code scan
juneau92, I suggest you stop by one of the auto parts chains that will do a free code scan and see if that uncovers anything. Sometimes the error codes are stored for several drive cycles and then cleared automatically.
I suspect you're ok, but checking the codes might give some insight.
Sorry I didnt reply earlier. Here is the list of stuff replaced:
1.Alternator (they say it was the cause of the whole problem, not sure how but that is their answer.)
2.Body computer
3. Fuse block
4.accelerator pedal assy.
5.4wd selector switch
6.some actuator by the transfer case
7.transfer case
8.4wd computer
I think there might have been something else. They had the truck for about a month. Ever since then, everything has been smooth sailing. Mileage at the time was about 18,000. Truck just hit 30,000. Hope that helps.
2.Body computer
3. Fuse block
7.transfer case
8.4wd computer
:wtf: That is quite possibly the strangest combination of things I have heard of...
Ill agree that it sounds like it was the gas cap was not tightened and threw your code, and after refueling it was tightened and cycled through.
Mine came on last time I was towing a my Toy Hauler. It was an O2 sensor on mine. My Extended Warrenty has been used for the VSC computer, and the o2 sensor already. It paid for its self, almost.
You're not kiddin....the chance of all that being faulty at once is, uhh, non-existant LOL
Sounds like either an O2 sensor or possible the gas cap. Really easy to tell which... tighten the gas cap and drive for about 50-60 miles and the lights will go off if that was the reason.
I have had 2 O2 sensors replaced on mine. Dealer repair manager said they had a bad shipment of O2 sensors during my production run and they were failing early.
