dash lights on after suspension work
bulldogtaxi
Today i changed my front struts and ball joints. When i went to back my runner out of the garage i noticed the following lights were on
VSC TRAC
VSC OFF
ABS
Emergency brake
All are on and not blinking. And I did accidently leave the key on in the truck while working on it. I was thinking i need to do the zero point calibration??? Or Maybe it could be a wheel speed sensor???
Any help is appreciated
I don't know about the brake, but the other 3 sound like you need a zero point calibration. It's easy, I used a short piece of speaker wire. It can't hurt to try.
Heh, I did the struts on mine, and occasionally those 3 (minue brake) will come on, its been a month or two since though. Do you think I should try the zero point calibration?
Ok so it was the front abs wires going to the wheel sensors. niether one had continuity from sensor plug to the plug under the hood. So i removed both wires, Cut all insulation off and found the break. Soldered these back together shrink wrapped and reinsulated the wires. Reinstalled them and that took care of the ABS light and the E brake light. Then upon completing the Point Zero calibration the VSC lights dissapeared. :guitar2:
:bigok: Congrats!
