Dash lights?
ToyNutt
Yesterday I was coming home from work and stopped for some gas. When I restarted the motor the engine, abs, and traction control lights came on. I don't notice anything different but they continue to stay on as long as it's running. Any thoughts?
3.4L
130K
Whats the cheapest/easiest way to do that?
Take it to Oriellys, Napa, or any of the chain auto parts stores, they will tell you the code for free.
With your mileage, I am guessing front A/F sensor in the exhaust. But you'll have to get the code.
:cheers:
just got it checked, code P1135, A/F sensor. Maybe a short circuit or bad connection. Any help as to how to fix? Where is that sensor located?
Read attached for bank 1 sensor 1 location.
Google "p1135 4Runner" for a ton of reading material.
The code is for the heater circuit in the A/F sensor. It could be the wiring but they seem to go between 100k-150k miles.
Do you know when it was last replaced? Likely it just needs replacing. If so, look on Amazon for Denso brand.
Thanks for the help guys. I think it's the original so I'll probably just replace it. Any thoughts on how much they run?
