ToyNutt New member Jan 24, 2011 #1 Yesterday I was coming home from work and stopped for some gas. When I restarted the motor the engine, abs, and traction control lights came on. I don't notice anything different but they continue to stay on as long as it's running. Any thoughts?
GottaBeTRD New member Jan 24, 2011 #4 sorry to question your definition of "tight" but did the gas cap click tight?
notrayray New member Jan 24, 2011 #6 Year? Engine? Mileage? Time to find out which P code is stored in your ECU.
notrayray New member Jan 24, 2011 #8 ToyNutt said: 2002 3.4L 130K Whats the cheapest/easiest way to do that? Click to expand... Take it to Oriellys, Napa, or any of the chain auto parts stores, they will tell you the code for free. With your mileage, I am guessing front A/F sensor in the exhaust. But you'll have to get the code. :cheers:
ToyNutt New member Jan 24, 2011 #9 just got it checked, code P1135, A/F sensor. Maybe a short circuit or bad connection. Any help as to how to fix? Where is that sensor located?
notrayray New member Jan 25, 2011 #10 Read attached for bank 1 sensor 1 location. Google "p1135 4Runner" for a ton of reading material. The code is for the heater circuit in the A/F sensor. It could be the wiring but they seem to go between 100k-150k miles. Attachments eg043-07.pdf eg043-07.pdf 121 KB · Views: 4,769
Nelsonmd New member Jan 25, 2011 #11 ToyNutt said: just got it checked, code P1135, A/F sensor. Maybe a short circuit or bad connection. Any help as to how to fix? Where is that sensor located? Click to expand... Do you know when it was last replaced? Likely it just needs replacing. If so, look on Amazon for Denso brand.
ToyNutt New member Jan 25, 2011 #12 Thanks for the help guys. I think it's the original so I'll probably just replace it. Any thoughts on how much they run?
notrayray New member Jan 25, 2011 #13 Yes, I forgot to say to get the correct Denso sensor. Read this here.... http://www.toyota-4runner.org/3rd-g...c-trac-vsc-off-lights-again-1-year-later.html One for just under a c note here... Amazon.com: Denso 234-9002 Oxygen Sensor (Air and Fuel Ratio Sensor): Automotive :cheers:
ToyNutt New member Jan 25, 2011 #14 I'm going to order one this week and install it. Thanks for all the help guys, I really appreciate it!
