Daystar and Body Lift pics
techmen17
I'm most likely getting a body lift soon, probably Roger Brown. Thinking of going with the 1.5" BL, maybe the 1" since you don't have to worry about the steering shaft extension.
But before I do, I have a pic request. Anyone got any before and after shots of a body lift with the daystar kit? Or just a 2.5" lift and body lift?
If you could post up what lift you get, and what brand/size BL as well. THANKS
NATE
even the toytec 1inch BL comes with a steering shaft spacer. I went with the 1 inch bc I was more worried about the gap between the bumpers instead of the steering wheel spacer.. it's a PITA to install in the first place, the steering spacer is no harder to install than the rest.
I was looking at this a day or two ago and emailed Toytec asking about it. They advised using the steering shaft spacer because "without it the rubber on the steering shaft is stretched and could break in time, we didn't feel it was worth taking chances on a part like that." Makes sense to me, so I'd take that advice and use it on the 1".
Well that settles it, I'm getting the 1.5" then since I will have to use the steering spacer anyways.
But no pics from anyone?? Nothin?
