Daystar Level
orignalbrad
Hey guys, first post here.
So i've read though a lot of the forums on the daystar lifts.
So I've got an 03 runner with XREAS and the airbag in the back. I'm looking to get the 2.5" level up front but am wondering if the new easy install kit will have the front end looking higher than the back. If so I'm going to look into getting the air bag settings tweaked to make it ride higher. Thanks for all the help.
Looks great, how much did you have to adjust the RAS, or do just run it on the high setting without the fuse in?
I can't remember how high it is right now, somewhere around 37" from ground to fender. I think I have about a 1/4" difference from front to back. I can measure tonight and give exact numbers.
I adjusted the tie-rod that controls the valve to the compressor.
There is a PDF of this attached to the first post in this thread.
http://www.toyota-4runner.org/4th-gen-t4rs/102272-4th-gen-suspension-options-faq.html
read that, and at the bottom there is a PDF that will show you how to adjust the RAS
Here is my DS 2.5/1.5 with 265 70 17 Nittos
honda, truck looks great. I would love to put that 1.5 in the rear but with the RAS its not going to happen. What rims do you have, i really like the look.
youngrk
