Glad to help answer any questions you may have, but as far as advice that I can think of...
Fronts:
Bring your strut assemblies to a shop and have them compress the coils to get the spacers in. It'll make it a lot easier.
Don't mess with the ball joints themselves to get the fronts in/out. Just remove the 4 bolts on each lower BJ and that will give you enough room without breaking the seals on the BJs.
Make sure the top plate bolts are lined up with the bottom shock bolts before you decompress the coils (you won't be able to turn the shock w/ pressure on it. Just hold it up to the truck to see if it's lined up.
Rears:
The rear is easy, just drop the axle and slip them in, use a floor jack to raise the axle back up and bolt it in.
Expect your stock CVs to not like the new angle and leak grease. With the diff drop you may be fine, but expect it still. They will last a while even after the grease leaks out (mine lasted about a year dry with torn and duct-taped boots). New CVs shouldn't give you problems.
Lastly, I have to tell you, I hated my Daystars after about a year because they sagged my coils and I could feel every bump in the road. Got my OMEs and never looked back.
