Trying to get my front shock back in after adding the spacer,got the spring compressed,but not the shock.What am I missing?The whole thing is up on jacks,wheels off floor.
Take your OEM jack and place it in the wheel well and use it to push the upper control arm down a bit. It should give you the room needed to get the shock back in.
The key is removing the lower ball joint bolts.Pushing the lower arm down and popping in the lower shock mount.I wouldnt of had to loosen the brake or abs lines if I had started that way.
