I'm looking at getting a set of 17 Tundra split 5 spokes with decent tires for 400. I'm concerned they may not fit, I know the offset is slightly different. Will they rub?
As ChildrenOfBodom stated...will rub depending on your tire size choice. Also, keep in mind the offset is higher with these so they will come in a little closer to your control arms. I have 285's with a lift and still had enough room between the tire and the contol arm but ended up going with some spidertrax spacers for additional clearance. What plans do you have for your rig? That would probably help you decide on tire choice?
looking good spish! With the sunlight, they almost look color keyed to your runner
Thanks for the info, I'm going to just get them. They are cheap and I'll be kicking my self if I don't. They have 265/65/17 Yokahama Geolander A/T-S tires on them now, once they are worn I'll have the 3" lift on and will probably go with 32's since this is my DD also. What size would you recommend with 1" spidertracks? Or without spacers?
Mine came with almost new 285 BFG's. Since this is my DD I thought about downsizing to 265's because I didn't have a lift. Found a really good deal on a lift so I ended up giving into the mod bug completely! So much for being practical with the "DD". The 285's look right at home on the Tundra wheels. You don't have to go with the spacers but I felt better about the extra clearance it gives along with the wider stance. I went with 1.25" spidertrax. However, with the wider stance....now I rub on my front mud flaps when the wheels are turned all the way. I'll be getting a bodylift soon so hopefully that will resolve. Your Runner looks great with them mounted up!! If you go with the 3" lift..32's or 33's should be fine. Just beware of aggressive tire tread designs when running the Tundra wheels. You may want to stick with 32's to be safe.
I think so too, they look great on the 3rd gen.
Amen to that, I love the look. I've only had my 4runner for about a month and already got Tundra wheels, Deckplate mod, and Toytec Ultimate on the way! God I love modding cars! At least this one is cheaper than the Evo 9 I had before this.
wow spish, your right around the corner from me. im over here in surprise
I hear that! I had a Evo 9 before the 4runner, parts are pretty damn expensive, plus when you start with a $24K car plus mods, it can get out of hand quick. So glad I got rid of the Evo, only paid 6800 for the 4runner.I'm addicted to modding too (I guess that's better than drugs but probably just as expensive)!
