Deckplate mod completed-non techie
Ron Helmuth
Senior Member
I could have called this "go ahead and laugh-Part2"
I completed the deckplate mod this last weekend and I am a complete klutz with tools and following directions. I have seen estimates of around 1 hour to do this mod. With my teenage son we were able to get it done in about 3 hours total.
First suggestion: do buy a hole saw that fits the diameter of the circle you will be cutting. This alone would have saved us a lot of time for cutting and test fitting, live and learn.
I pulled 3 versions of how to do the mod from Yota Tech and IH8MUD and even T4R.
I wanted to point out that some folks have noticed that a
"sewer cap" from a Home Depot can substitute for a "deckplate" from a marine parts store. I mention it only because my SeaDog brand deckplate was not deep enough for it to stick out into the airbox, so I did not have anything to attach insect screen to on the inside of the box. I considered hot gluing just a few contact points for the screen inside the airbox or even trimming away the screw in "plate" of the deckplate to hold the screen. A sewer cap has more depth both in the screw in plate and the body itself.
I get the impression that many of you just run with the deckplate fully open like this anyways, and since I use the TrueFlow air filter I may just need to check it more often for bugs or other dirt and debris.
So rest assured, even a complete idiot can handle this mod and I have proven it.....
Results are seat of the pants but there is a definite "whoosh" or roar from the airbox when I put my foot into it. This mod has definitely improved the immediacy of throttle response in any gear, particularly noticeable in 4th or 5th gear as in the past I may have felt the desire to downshift, and now there is no need.
This now makes my total a whopping 2 for 2 mods that I felt I could not possibly do correctly and was able to save time and money by doing so myself.
If you are like me and somewhat petrified to cut up your airbox-rest assured it can be done and done properly. Removal and reinstall of the airbox itself was very simple, it was the cutting and trimming that took the time. If you are that worried, just find another airbox that will fit your truck, so you can restore it to stock if so inclined.
Time to re-modify the signature line again!
:bash:
A screen is nice to keep larger debris from actually getting to the filter.......
Randompicsfor6-07054.jpg~original
Randompicsfor6-07053.jpg~original
factory wing
I got the wing and am maybe a week from install -I am hesitant to be drilling holes on the body of my rig-it never had the deflector installed before.(and as stated before I am an idiot with tools)
Then I am going to let my son take a crack at painting it the body color (white) and then consider using it for my 'stickers' or an homage to my friend now serving in Iraq.
Ron Maiden -I like that picture of the screening so I presume the Beckson deckplates have a deeper recess than my budget dollar
Seadog? mine is literally just as deep as the airbox wall.
Since you already did the deck mod this won't help but I just did mine yesterday with the same bargain plate and I just put a screen (way bigger than the hole) over the hole, put some waterproof sealant and then pushed the deck plate in trapping the screen in then cut off the excess. Worked well.
I got everything needed for this mod. I'm just curious is there a step that needs to be taken to waterproof the areas around where you put the screws in.
Thanks.
good thought Hadji
good idea Hadji I wish I had thought of that before I sealed it all up.
Dabadina- as Ron Maiden indicates-the sensor safe sealant actually mates the entire plate to the surface of the airbox-but another small dab on the screw threads would likely waterproof/seal the screws themselves.
Re: factory wing
Not to hihjack this thread but I installed the factory rear wing on my 02 4runner. Had to drill the body and install the rivet screw thingys into the body to hold the wing in place. It is definitely a do-able project. Just take your time and before you drill into the body -- really get a good idea of where the wing will be sitting once bolted on. measure measure measure and then test fit a few times before drilling.....then....do it.
HAHA!! been 2 years since i did that and it hasn't flew off yet!!!
:D :D :D
Oh,, and good job with the deskplate mod..It makes a considerable difference.
thanks 2000se
glad your deckplate went well
I am still maybe a week away from wing install but I have Irbis OffRoad lined up to do the drilling.
I lack confidence in causing potential body damage to my own rig, I will drill on someone else's anyday!
