Defiance's Build
My old "Rebuilt" motor is in the truck. Took a few days to swap engines and transmissions, but we got it to run.
The grounds to the battery were all bad, I replaced all of them.
The TPS is bad - Still haven't replaced yet.
It took a few weeks to get the O2 sensor in the truck. (Bolts on the header were so rusted, I had to grind them off)
The truck runs now; I have it insured and registered and on the road.
Has a misfire at idle, still need to look into that.
Just my luck though, the truck will not start. Only way to start the truck is bump starting it.
I replaced the starter, again, but that's not the problem.
I've tried using another car to jump it, but the battery is good.
You can even hear the starter trying to engage.
I have no idea what the problem is.
It could be the solenoid, but I doubt it.
Going to drive it to the shop today, and see if I can play mechanic.
