Denso PK16TT Plugs
Crzyrzr
Ok I know there have been some posts on this subject but just found an awesome deal on this plugs $1.99 each. So thinking it is to good to be true.
Question is this: Are these plugs any account? Must be a reason they would only be these price when other denso plugs are 6 or 7 bucks.
:shrug:
:shrug:
Probably an overstock issue.
Those aren't the correct plug for the 3.4 liter. It should have two grounds.
Bingo. Look up the NGK plugs that others here have used here and use them. You can get the normal ones or the platinum ones. Don't skimp on this item, it's not worth it.
Thats what i was thinking so no densos go ngks. Thanks for the input guys just making sure before i make a costly mistake.
There is one other brand that people seem to agree are ok, but I don't recall if it was denso (I think it was). I would just go with NGK, they seem to be the most popular.
Denso is fine as long as you get the correct one for the application. I got my Densos from Rock auto for $1.79 a piece. The part number is:
Denso Multi-ground plug 3194 K16TR11
