Just wondering if the 5th Gen owners are getting the driveline thump/bump/clunk and the sulfur smell that the 4th Gen owners have had to put up with. Or, did Toyota finally address these annoyances.
Sulfur smell is there......not sure about the thumb/bump/clumbs though. Rides pretty good.
I don't have the sulfur smell at all. No driveline thumps either. 13k miles.
Only time I had the sulfur smell was when I first got and floored it with the back window down. Pretty sure all new vehicles do that except most don't have rear windows to let the exhaust in to smell it. Hardly any vehicles have functioning rear windows these days. Just be glad 4Runners still have them.
I put DT headers with pre cat deletes on and never smelled it again.Easy fix for that though is to route the exhaust out the side behind the rear tire as the air flowing under SUV's tends to roll back up and over, thus bringing in fumes .
The drive line thump issue is actually coming from the telescoping rear driveshaft. It can happen on all trucks,not just Toyota, that have the same set up. IMO.... 99% of the time it comes from poor maintenance. Manual says to lube your driveshafts every 5k miles and usually gets passed over at dealerships. I've always done my own maintenance and NEVER had the problem with over 100k on my last Runner and almost 30k on this one. Worked on a friends F150 years ago that had it and ended up changing the driveshaft it was so bad.
I never had the drive line thump either but I grease my drivshaft regularly. Also never had the sulfur smell or any other problems.
I drove a 2005 4th gen for 190,000 miles and I current have a a 5th gen for 5,000 miles. Neither have ever had the sulfur smell, or cluncking you cited.
I had it on 5 GMC 1/2 ton truck in a row. Using a high moly content grease was only a partial fix. My new 4 Runner is too new to know yet. My only concern with my new 4Runner is that if I start greasing the driveshaft,---, how much moly grease will eventually work its way into the transmission fluid as it mixes with the tx fluid on the tailshaft of the tx. Transmission fluid is supposed to keep this area lubed but its a dilution process. I hope there are not any English teachers reading that run on sentence.![]()
