Did your OME 891's sag?
I already have the bilsteins that are rated for 1.5-3" lift, but thank you for thinking of that!
Those are an inch shorter extended length than the 4th gen shocks if you are trying to use the full droop that the landcruiser 210V's would allow.
13.84"-22.84" vs 14.91"-23.50"
I installed firestone airbags and am running them at about 15 PSI in this pic with about 150 lbs of weight in the back
I did install airbags to help with the sag weight since.
Would you guys mind listing the part numbers for the airbags you ordered? I've seen several threads with folks trying to find airbags with the right dimensions for OME 891s, so having that reference available would be awesome!
When getting the 4th gen shocks the owner does need to make sure bump stops are long enough (the collapsed length being 1” longer than 3rd gen). You wouldn’t want to blow the shock at full compression. That is sometimes overlooked area.
A shock rated for just 1.5” lift is shorter than a shock rated for 1.5-3” lift? I’m confused.
H.Sikina
