Hello all,
Found this forum a couple of days ago and have some questions. I have a 98 4Runner V6, recently it's been sort of temperamental. If it's a cold start there is no issue, however about 60% of the time on a warm start it will die immediately after starting. For example, if I've been driving for anywhere from 5 - 45 minutes and go to a gas station and turn it off and start it when I come out about 3-5 minutes later it starts right up and then dies. It will stay running if I feather the gas for a minute and drive out of the lot using the brake and gas; about a minute or two of this and it usually is fine. I have used Seafoam, injector cleaner, new air filter, new plugs - thoughts on what else to try? I saw a post on here about Seafoam stating there were other things you should manually clean after using Seafoam, what all should I look at?
Thank you in advance
