Different Sound After New Battery
Chilow
Strange question, but has anyone ever replaced a battery and the car sounded different when cranking it over?
I’ve replaced several batteries in the past and the sound when turning it over always remained the same. I just went from the original Panasonic to a Northstar 24F and I can hear a difference in sound when turning it on. It’s hard to explain. Almost like a different tone when it starts up.
If your other battery was weak then your starter many be spinning over a lot faster.
It seems to take the same amount of time to start. The Panasonic battery was 5 years old though so that could be it.
My Panasonic was 7 year’s old when I replace it. There was a very noticeable difference in starter performance with the new battery.
The cells in a five year old battery will be noticeably deteriorated when compared to a new one. Also, a group 24 battery will typically have a higher cranking amp rating than a group 35. Additionally, an AGM battery will have a slightly higher output voltage. These two things will contribute to a faster cranking starter.
I noticed a lot faster ignition firing when I switched to my odyssey, can't really speak to the sound though
Old battery was prob weak. The change in sound happens over time so you don't typically notice until you swap it out.
MaximussK
