Differential bolt torque specs
aqua33
Does anyone have the torque specs for the 2 differential 19mm bolts that connect to the front cross memeber???
Thanks.
That's why I gave the whole diagram rather than guess at which bolts you were asking about.
Now that we know what you are looking at: Yes, the 2 long vertical bolts are 101.
Kmvreter,
Thanks for the diagram it was a big help. Where did you find the diagrams?
I installed the differential 1" drop kit last night and torqued them to 101+ ft/lbs.
Thanks again.
dont forget they came thread locked from the factory, so you need to put on plenty blue loctite before you bolt it back on.
Loctite
Actually now that you mention it there was no sign of any thread lock on the factory bolts. They came off rather easily. The new bolts from ReadyLift come with the plastic/wax nuts are hold very well.
