Cape 4RUNNER
What wire do I connect my dimmer wire from my head unit to in my 03' JBL T4R? Or do I need to run a wire to the dimmer controls switch?
Thanks in advance!!
Thanks in advance!!
The green wire pin 10.What wire do I connect my dimmer wire from my head unit to in my 03' JBL T4R? Or do I need to run a wire to the dimmer controls switch?
Thanks in advance!!
That should do it. All it does is switch the gps image to night mode when you turn on the headlights.:shrug:So just splice the wire from my h/u with this and thats it?
I just installed a DNX-6160. I don't remember which wire the dimmer wire is (Crutchfield made that part pretty simple with their harness), but I can tell you how it is working on mine. There is an option in the Kenwood setup screens that allows me to choose to either dim when my lights are turned on (via the dimmer wire I assume) or to dim based on the GPS switching to night mode. The amount of dimming is also selectable via that setup screen but the truck's dimmer (the wheel on the left side of the dash) has no effect on the brightness of the stereo. That would make too much sense. Even at the most 'dim' setting on the stereo, it is still WAY too bright at night.
