Direct replacement switches
Swimmerboy2112
Hello all,
Like the title says I am looking for direct replacement switches for my 98' 4Runner. I'd like to add foglights (and other stuff later on), and was wondering if anyone makes direct drop in place switches.
I found these from Slee Offroad and they appear as though they'd fit, just seeing what anyone else can suggest.
Scroll down to Auxiliary Light Switches
Slee - Electrical Switches
These switches are one place Toyota standardized for quite a while. And yes some of what Slee offers will work for you. You can of course, do enough research to find part numbers for what you want and buy them from Toyota. If you have the time, you can visit some wrecking yards and probably find some there too!
Of course the later Toyotas use a smaller footprint, I'm sure you saw that.
Good to know. Looks like I'll be doing a little hunting in the local junkyards.
I don't suppose you know any places that make direct fit switches with different labels like "winch" and other stuff on them?
This is what I used for my fogs on my '99. Just Google "Toyota fog light switch" and plenty of pics will come up. I think its factory Toyota. It fits perfectly in the switch blanks and blends in well with the other dash switches.
I saw one like that it was on a set of dealer installed fog lights on a 97 4Runner. That's not a bad switch but I'd prefer the kind you push in and out not the toggle type. I know I'm picky.
Got ya. Yeah the only issue I've had with this one is I can't seem to get it wired to backlight the switch. Tried several different slots in the fuse box but none have worked so far.
You don't need to go to the fuse box for back lighting. Simply tap into the same wire on an existing switch, and they'll light up together.
Reviving this thread. Are there any updated OEM style switches? Preferably push button, but if not, I’d consider rocker style too for turning on my lightbar.
