Discovered oil leak *need assistance*
I don't think a synthetic oil manufacturer's website is the best source to prove a point that synthetic oils don't cause leaks, haha.
However, I will say I learned something from this, and perhaps the newer synthetic oils have solved the issues I've seen personally. It kind of proves both of our points: synthetic oil can cause leaks for exactly the reasons I described/have experienced, but chances are that it won't. :):
If I put new, fully synthetic oil in my older engine, will the seals leak?
This question comes up a lot from people who've just bought a used vehicle and are wanting to start their history with the car on fresh oil. The short answer: generally speaking, not any more. The caveat is that your engine must be in good working order and not be leaking right now. If that's the case, most modern oils are fully compatible with the elastomeric materials that engine seals are made from, and you shouldn't have any issues with leaks. The longer answer:
Mixing Mineral and Synthetic oils - the old and busted concepts
For the longest time, I had this to say about mixing mineral and synthetic oils:
If you've been driving around with mineral oil in your engine for years, don't switch to synthetic oil without preparation. Synthetic oils have been known to dislodge the baked-on deposits from mineral oils and leave them floating around your engine - not good. It's wise to use a flushing oil first (see below).
If you do decide to change, only go up the scale. If you've been running around on synthetic, don't change down to a mineral-based oil - your engine might not be able to cope with the degradation in lubrication. Consequently, if you've been using mineral oil, try a semi or a full synthetic oil. By degradation, I'm speaking of the wear tolerances that an engine develops based on the oil that it's using. Thicker mineral oils mean thicker layers of oil coating the moving parts (by microns though). Switching to a thinner synthetic oil can cause piston rings to leak and in some very rare cases, piston slap or crank vibration.
Gaskets and seals! With the makeup of synthetic oils being different from mineral oils, mineral-oil-soaked gaskets and seals have been known to leak when exposed to synthetic oils. Perhaps not that common an occurrence, but worth bearing in mind nevertheless.
Mixing Mineral and Synthetic oils - the new hotness
That's the thing with progress - stuff becomes out-of-date. Fortunately for you, dear reader, the web is a great place to keep things up-to-date, so here's the current thinking on the subject of mixing mineral and synthetic oils. This information is based on the answer to a technical question posed on the Shell Oil website.
There is no scientific data to support the idea that mixing mineral and synthetic oils will damage your engine. When switching from a mineral oil to a synthetic, or vice versa, you will potentially leave a small amount of residual oil in the engine. That's perfectly okay because synthetic oil and mineral-based motor oil are, for the most part, compatible with each other. (The exception is pure synthetics. Polyglycols don't mix with normal mineral oils.)
There is also no problem with switching back and forth between synthetic and mineral based oils. In fact, people who are "in the know" and who operate engines in areas where temperature fluctuations can be especially extreme, switch from mineral oil to synthetic oil for the colder months. They then switch back to mineral oil during the warmer months.
There was a time, years ago, when switching between synthetic oils and mineral oils was not recommended if you had used one product or the other for a long period of time. People experienced problems with seals leaking and high oil consumption but changes in additive chemistry and seal material have taken care of those issues. And that's an important caveat. New seal technology is great, but if you're still driving around in a car from the 80's with its original seals, then this argument becomes a bit of a moot point - your seals are still going to be subject to the old leakage problems no matter what newfangled additives the oil companies are putting in their products.
Source: Car Bibles : The Engine Oil Bible
synthetic oils have a way of finding their way out of an engine..its like houdini oil. if there is a marginal seal anywhere in the engine the synthetic oil will find it and exploit it.
case in point:
my wifes 2008 gmc denali ran great the first 10,000 with dino oil--no leaks of any kind. then a oil pan leak developed with in the first month of switching to synthetic-
i dont think synthetic oils CAUSE leaks they just point them out to you:naughty:
