**Ditch Light Bracket + LED pods - Group Buy**
It appears that all ditch light bracket combos have been shipped.
For anyone that had a delayed order - You should have a coupon code in your packaging as 'compensation' for the delay.
If you didn't receive one, please email Rago Fabrication.
Rago wants to do another group buy on their products, if anyone has any suggestions, post up!
I'd be in for a set of rock lights.
I didn't get a discount coupon with my shipment also.
Also does anyone know how to connect the toyota square ditch light switch to the wiring harness?
I had a paper with wiring diagram to connect the harness wires to the connector that came with the switch. I can probably find and post a picture if needed, or pull the dash to see which wires went together.
There was one extra wire for power so the switch would be lit when the headlights are on which i used an add a circuit fuse for. I may go back and wire it to one of the other oem switches so it will be dimmable.
I found the wiring diagram on their website. Quick question. My switch doesn't seem to dim with the rest if the instrument lights. I hooked it up to the green wire on the wiper heater. I just wanted to know if I installed it incorrectly.
Melissa from ragofabrication confirmed that they do not dim.
Here is my install, looks good. Just need to adjust when it gets dark.
I had the same issue, called rago, and learned my red wire and green wires from switch harness needed to be switched
alexaturner
