Diver Deuce's Thread
Air Onboard
I finally took the time to run an air hose from the ARB CKMTA12 on the passenger side engine bay to the driver side cargo area tucked away in the jack compartment.
I mostly followed [MENTION=55815]Okki[/MENTION] thread for the routing except I do not have XREAS.
I got my old plate number from Florida on my Arizona plate. I really like the color scheme and the number tickles me because people read into it too much.
Gobi Ladder Install
Okay so with a Gobi Ladder install you have to upgrade your hatch struts.
I'm having issues with photobucket on mobile it's complete crap now.
So here's a link to imgur...
[URL="https://imgur.com/a/RIAQq]Simple rear hatch strut install[/URL]
IMAG0246.jpg~original
Serpentine Belt Replacement
Welp, I decided to change out the serpentine today and I'll say it was pretty simple. Here's what you need:
-14mm deep socket or socket with extension
-Ratchet
-Bando 7PK2150 serpentine belt ($12 on Amazon) (it does fit)
Here's the routing to make it easier... also the easiest way to remove the belt after getting it off all the stuff it is routed on is to pull it around the fan. Easy peasy. I'm not gonna go into detail because you're all a bunch of smart people.
Weatherstrip thanks!
Well I've been putting this off long enough and I'm still not sure why. It's super easy to do, just roll the windows down and pop out the old moldings. I'll post some pics in a bit.
But for now here's the part numbers for all doors (left/driver, right/passenger):
Front Right: 75711-35011 $40.02
Front Left: 75712-35011 $40.02
Rear Right: 75721-35011 $40.02
Rear Left: 75722-35011 $40.02
Rear hatch: 68292-35041 $20.35
Bump! This old post made replacing all of my window weaterstrips super easy. My floorboards (and everything on the water's path through the doors to them) thank you [MENTION=60893]Diver Deuce[/MENTION]!
Super easy, very inexpensive, nice and bright.
I bought a 18w Flush mount LED by "Kawell" on Amazon for $18.99 with free shipping and a pin switch for $4.59+ $2.89 S/H. The install was pretty straightforward: mount the LED bar, run the positive wire through the hood to the battery, run the ground to the pin switch adjust accordingly and you're in business.
IMAG3029.jpg~original
IMAG3030.jpg~original
Damn, this is a great idea.
It's been a while since I've posted here. Here's the newest mod. RTT. The goal is to build a trailer that will be home to the RTT full time so we can have a base camp, but for now it will live on the roof rack.
5th Gen Clockspring Replacement
So I've felt with a dead horn for quite a while now and just never really wanted to deal with the dealership taking $500+ just to make my horn go beep beep... I have also found that some members have had issues replacing theirs (codes thrown, fault lights). Here is my experience.
The Part:
84307-30090
2010+ 4Runner Clockspring / Spiral Cable
Yes I bought mine from eBay for $22.97 with free shipping. Yes, I assumed the risk. Does it work? As far as I can tell, Yes.
How to replace:
0. Make sure your steering wheel is at the 12 o'clock position and the wheels are straight.
1. Unplug your battery
2. Get your panel tool and pry off the covers on each side of your steering wheel column.
3. Use a torx bit to undo the screws. You won't be able to get them out due to plastic retainers.
4. Your airbag is now loose. Peel that bad boy back and use a small flat head to undo the plugs by prying up (carefully) where the arrow points down. You can remove these plugs by a little tug. The ground wire has a clip that you need to push on with your small flat head to get it undone.
5. Use a 19mm socket to remove the steering wheel retaining nut.
6. Unplug the two white clips that are plugged into the clock spring, then give your steering wheel a good tug and it should come off. If not well then you need a steering wheel removal tool.
7. Remove the bottom steering wheel shroud by first unscrewing the two Phillips head screws. Then press in the top piece on the sides and pull down on the bottom piece.
8. Remove the two plugs (black and yellow) connected on the bottom of the clockspring.
9. Remove the clockspring by depressing the clips on each side with your fingers it should remove easily.
10. Install the new clockspring ensuring the arrows are aligned on the bottom. The piece behind the clockspring has two holes that will align with two pins on the back of the clockspring. Push in and it will clip in.
11. Your new clockspring has an Orange pull pin. Pull it out.
12. Reinstall the bottom plugs
13. Reinstall the steering column shroud.
14. Reinstall steering wheel.
15. Reinstall airbag plugging in plugs and ground.
16. Screw in torx screws.
17. Replace covers.
18. Plug in battery.
19. Your horn should be back in business now and you should not have any codes thrown or fault lights.
Hopefully this helps. I'll post photos later since I didn't take any pics at the time.
Bunkstaff
