Mtneer001 said:To the Do it yourself guys (DIY) - what do y'all use to lift your 4 Runner when you change your own brake pads?
Thanks.
TechWrench said:3-ton floor jack and two 10-ton jack stands.
fun4runner said:how much does these jacks cost and which is the best place to buy them, can i use the same stands on my other car (accord 2002)
thx
Uneek said:You want a garage jack (or some call it a heavy-duty floor jack) with a 2.5-3 ton range. Don't get the narrow skinny type floor jack. Aluminum racing jacks are 2 ton capacity typically. They're much lighter if you ever need to transport it around. But I personally like the all steel heavy duty jack over the aluminum racing jack. A good jack will be about $100.
For jack stands make sure you get a pair/set that has a higher capacity than your jack. I have a set 4 ton stands and they're quite a bit taller when at its lowest than my 3 ton stands. The taller stands isn't that big of a deal, just that you have to lift the car much higher off the ground before you can get them under it. I paid $30 for the 4 ton stands a few years ago.
fun4runner said:so 4 ton stands means the combined capacity of the pair is 4 ton which i suppose will support a 4runner (4runner may be ~ 2 tons )
tks for the feedback
TechWrench said:I believe the rating is for one stand, but I don't think you can make the leap that two 4-ton stands can support 8-ton. I don't pretend to know all the mechanical load formulas, but it has to do with how the stands are placed, and how the load is balanced between them. I'm sure someone here has a better mechanical engineering understanding of how the load sharing works. For my purposes, I usually try to go no more than 1/3 to 1/2 of the rating of the equipment I am using. This allows me what I feel is an adequate safety margin. Also, the minimum/maximum working height of most jack stands increase as the load rating goes up. So if you need additional work height, you will usually have to go to a higher load rated unit. What I feel is as important as properly sizing the equipment to the load, is proper placement and use. The heavier rated stand isn't going to be any safer than a cheep one if it isn't set on a level, stable surface and supporting the vehicle at a proper point so it doesn't slip.
